Adds the specified VLAN as the network VLAN on the specified PVLAN.
| name | Specifies the name of the PVLAN to which the VLAN is added. |
| vlan_name | Specifies a VLAN to add to the PVLAN. |
N/A.
The VLAN must be created and configured with a tag before it is added to the PVLAN.
The following example adds VLAN "sharednet" as the network VLAN for the PVLAN named "companyx":
configure private-vlan companyx add network sharednet
This command is available on all platforms that support the Private VLAN feature. The features and the platforms that support them are listed in the Switch Engine v33.1.1 Licensing Guide document.
